Disables OSPFv3 on one or all VLANs or tunnels (router interfaces).
vlan_name | Specifies an IPv6 configured VLAN. |
tunnel_name | Specifies an IPv6 tunnel. |
all | Specifies all VLANs, or tunnels. |
N/A.
None.
The following command disables OSPFv3 on VLAN accounting:
configure ospfv3 delete vlan accounting
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
